Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Keeps Throwing Codes
  1. #11
    Pittsburgh, PA
    just cause its not broke doesnt mean it wont break.
    IMHO a mail order should only be used as a base
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    MidnightRider Guest
    Quote Originally Posted by chevrolade View Post
    SAME HERE THATS WHY I WENT WITH HIM.
    I HAVE NOTHING TO MONITOR MY A/F RATIO
    THE INJECTORS,WHATEVER COMES WITH THE 112 RADIX MAGNUSON42-44?
    AS FOR FUEL,STOCK FUEL PUMP WITH MAGNAVOLT FROM CHARGER KIT.
    IM ONLY AT 5-6PSI,IM ALSO RUNNING TR6NGK
    ok man bad mistake that is the most important guage period be easy on it till you have the right eequipment or you could blow it up
  3. #13
    UPDATE:
    ill be getting my gauge tuesdaythanks to melissa and nelson performance
  4. #14
    San Antonio, TX
    Those codes aren't as bad as it sounds. Those codes are caused by a vac leak or a bad o2 sensor. Or, it could possibly be a tune, but if it just started happening... you didn't mention how long it's been doing this.
    Those codes will not set during a wot run, more than likely, at wot it's rich, but like the other guys said, you never know until you check it with a wb.
    I command a safe a/f ratio in the calibration, however, commanded and actual a/f ratio are two different things.
    Those codes are set during idle and normal driving. For some reason during normal driving the pcm can't add enough fuel to keep the ltrims in line. SO, once they hit their max limit, the pcm sets this code.
    If extra air is entering the engine that the maf is not detecting, then the pcm can never add enough fuel to compensate. The pcm will over compensate and continue to add fuel to cure the false lean condition, but of course it never will as long as there is a leak somewhere, pretty much the same thing with a false reading from the o2 to the pcm, in closed loop.
    A bad o2 sensor is at fault, most of the time, when a customer complains about his truck running fine during startup, then after about 2mins (when closed loop happens) the truck runs bad.
    Send me an email or call us when you get the wb on and let me know what it is during wot, actually during any rpm and boost level.
    Hope this info helps, and get your truck up here for a live tune!!!!
    ttyl,
    allen
  5. #15
    ttyl,
    allen
    hey allen thanks for the info,yea this has been going on since i installed the blower.about 3months.true,the engine light wont come out at wot,it only comes out during normal driving,after wot runs. .i hope it aint a vacuum leakhow the heck would i find that?Well yea ill let u know tomorrow,where my a/f ratio is at.ill double check all vac lines as well.
