Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Best Place to order Traction Bars?
  1. #11
    College Station, TX
    Does FabTech make traction bars or are they more of a long trailing/pivot type arm. I thought that was a lift company...
    They actually make more than you think! I thought they were just that until I just looked a second ago..
    i seen i forget what company makes a triangleated Long bar setup
    I think thats AME but Im not sure..
    Quote Originally Posted by Justin_Inc View Post
    add and extra leaf to the front of the leafs, or try spring clamps on the front of the pack. will work amazingly well.
    Adding more leaf? You mean Add-a-leaf? Thats more lift and axle wrap I wont want though! Lmao! The only Add-a-leaf I would ever run is a zero rate because it virtually changes nothing except adding an inch.
    Greg- Thanks for the site Ill check it out!
  2. #12
    add a leaf = higher spring rate = less wrap. your wrap is coming from your blocks
    ooooor you could just lower your truck!
  4. #14
    College Station, TX
    Quote Originally Posted by sleeper1500 View Post
    I know exactly where the wrap is coming from. Thats why I want the bars installed to compensate.
    Quote Originally Posted by ///Audience View Post
    I LIKE THE WAY YOU THINK!
    Ive been considering really hard taking the body lift off and selling it for cheap.
  5. #15
    Aug 2005
    St. Anthony, Indiana
    the bars will eliminate all axle wrap.
  6. #16
    Winnipeg, Manitoba, Canada
    Quote Originally Posted by Aggie View Post
    No you dont 'add-a-leaf'. Go to a spring shop, and get half a leaf (yes they sell them) add it to the FRONT of the leaf pack, it will not lift the truck, or really change the spring rates at all. once the HALF leaf is installed in the front of the pack and then clamp them with leaf clamps. Your ride will not change at all and it will eliminate axle wrap by stiffening the front of the leaf pack.
    Its a tried and true method. Dodge has done it for YEARS with they're 'superstock' leaf springs from way back in the 60's. I've cut some pretty serious 60ft times in the past with a setup like this. Best part is it look stock
  7. #17
    College Station, TX
    I didnt even know that. Thats some interesting info. Ill look into that as well....
  8. #18
    to go along with the superstock springs.... i recall some even placed specifically cut springs in certain orders to help aid in traction as well
    Lou from muscle car did this a few years ago with Project blue hair.
    Yup, you can really mix it and matching to suite your setup, its a tried and true method that works amazing. sure its more work than just throwing up some slapper bars but IMO is a much better, more reliable and consistent setup that will last years without any issues. I've tried damn near every traction device in the book, and when keeping a 'stock' suspension this is one of my favorite ones.
