Results 11 to 12 of 12
Thread: 6.0L 4l80E 2wd Harness, Ecm, Pedal, TB, Maf
Threaded View
    PadreSmith/ecm - Photobucket - Video and Image Hosting
    Selling a nearly 100% complete 6.0l Harness. Harness out of a 2004 Chevy Silverado 2wd automatic 6.0l with the 4l80E. The engine harness, fuse box, battery cables, ecm, 4 02 sensors, interior harness, body control computer, throttle body (dbw), maf, gas pedal (dbw), and interior harness are included.
    Only pieces missing are connections at all doors for the speaker wires. I cut them to take the quick connect. The front headlight connectors and turn signal connectors were also cut. Other than that the harness is complete and uncut anywhere else. The maf works but it is missing the plastic tabs that attach to the intake ducting. It works but you will need to use duct tape to hold it to the intake ducting!!!
    Harness was powering the 6.0l without any codes when pulled 1 week ago. Pcm is included and the numbers can be found by looking at the pics. All fuel injector connectors are present and also the 02 sensors. The auto harness is also intact and not cut in any way.
    I'll take paypal with the extra 3% fee and also money order or cashiers check.
    Any questions let me know
