Good info G. I was gunna mention your stuff once I saw his note about the Aluminum 5.3. Seeing things, I am thinking your truck might have the L33 motor--which is the same one this guy is running. I am not 100% certain, but I am thinking the JG trucks may have had the L33...
Anyway, if you are considering a stall up to a 3200, then you can spec a pretty healthy cam for your truck. I would advise a custom grind from Comp. I would also recommend that your cam has a healthy duration number...5.3L love larger durations.
- You may not post replies
- You may not edit your posts
