you can buy 3M adhesive remover from either oreillys or autozone...best bet to heat up the area then grab and pull...i didnt use fishing line but i did my in the heat of summer and i have a black truck so i didnt even need a heat gun, everything was nice and soft
06 silverado CC Volant CAI/ Corsa Sport exhaust
dynatech supermaxx headers/cats
LPE GT2-3 cam/ Comp 918's/ Rods
Eaton LSD 3.73's
IAT Shocks
DANNY TRANNY w/2800 TCS billet verter
275HP and 293TQ Pre Cam
314HP and 303TQ post cam
If you dont like the look and dont want to polish it after you remove it, you always have the option to put it back on.
2007 Chevy Silverado Classic 4.3L V6
Magnaflow Muffler, CFM Technologies CNC Machined High Flow Vortec Throttle Blades, STS Rear Turbo, Intercooler, Accell Distributor and Coil, 8mm wire, Autolite Platinum plugs, Runs out of fuel at 4000RPM. Marine intake with larger injectors soon. Hoping to squeeze 10psi.
The darker the color, the more likely you'll be able to see where they were unless you buff it out really well. The only exception is white. It'll show some too unless it's worked out.
my door speakers are 5.25,
and i just did an 06 crew cab and the fronts and rear speakers were 5.25,
go to crutchfield.com, and it will tell you what size you need for your year, model
kind of seems like an odd size speaker,\
edit: i just checked crutchfield and it says that they are 5 1/4 but will also fit 6 1/2, not sure how unless there is a punch to make the hole bigger or something? Thats 1 1/4" bigger seems like a big jump to me?? Anybody actually changed theirs out themselves that knows if it will fit a 6.5 or not?
The correct speaker size is 6.5 inch front, 4x6 inch rear. I installed Infinity Kappa 60.5 front, and Polk Audio plate speakers rear.
2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
Yup--6.5'' in front. You can go with a 6'', but some fab work to the stock plastic speaker housing is needed.
