Results 11 to 20 of 21
Thread: 4.56 Vs 4.10
    College Station, TX
    Accurate Machine Works
    Instructions for installation are there.
    2100 isn't bad. Over 2500 sustained is what I would worry about.
    Thanks Greg!
    Quote Originally Posted by 06 4.8 View Post
    Would 2100RPM be to much to run for a 12 hr trip? Where does the can and filter go and how much are they?
    i have 4-10 with 29 inch tires i drive 30 miles every day with no problem some time i run about 80 it puts rpm about 2500. your truck having those 22' you wold love 456. 31 inch tires puts that 3.23 gear like a 2 something. every inch over stock is a 10 points off your gear.
    99 silverado 6.0 scat rods,patriot heads,ls6 intake, 595 595 238 242 112 custom grind,tune built-4l65e 4500 stall 4-10 gear
    Okeechobee, Fl
    Thanx guyz, I think I'm just going to order the 4.10's from summit. Will I have to get an installation kit to go with the gears or will my stock stuff be fine? Truck only has 25,000 miles if that helps with answering the ?
    49 Ford F1
    College Station, TX
    Always buy the kit! I think its called the GM master install kit? I believe you have to when doing a gear swap! Unless your like me and know someone who wants to swap axles
    Are you gonna keep the grenade or buy an LSD or trutrac or something?
    Okeechobee, Fl
    I have a 1 tire fire I will be buying a truetrac.
    49 Ford F1
    College Station, TX
    Well done good sir! lol
    Okeechobee, Fl
    Why thank you kind man! LOL
    49 Ford F1
    College Station, TX
    uh oh....
    Okeechobee, Fl
    It's off of Little Rascals.
    49 Ford F1
    Leave it up to the Aggie to turn this thread gay...
    Calm down girls...
