Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 46
Thread: powerstroke...
  1. #11
    Feb 2008
    Arizona
    I found a 2003 chevy.. 6" lift kit, 35" mudders, exhaust and programmer.. Will that work???
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
  2. #12
    Minus the lift, tires, exhaust, programmer, and only if it's had the injectors done....LOL. That's the main thing, the injectors. I'm really scared of buying an older used diesel from a guy that had a programmer on it but that's just me.
    My FIL has a 12-valve Cummins with 200K miles and the original clutch...LOL. The worst thing about the Dodges is the fall apart interior and the horrible auto transmissions.
  3. #13
    Feb 2008
    Arizona
    I know the guy who owned.. he is my outfitter partner, and I know that he didnt run the truck very often.. he just used the programmer to tow..
  4. #14
    Oct 2007
    Bentonville Ar.
    Hand down get a cummins. I worked for my buddy's diesel shop and that things came in all the time with 300 to 500k miles on the original build. They also have a forged bottom end as to where the ford has a PM type rod. i am not real big on a dodge truck but you cant beat the cummins with a 5 or 6 speed IMO. The only thing a dodge really has problems with is the lift pumps get weak and will burn up the fuel pump. Put a fuel pressure gauge on it and you will be good to go
    just a tow package
  5. #15
    southside VA
    i like the 12 valve cummins, u can get major power with some work, i never liked the powerstrokes
  6. #16
    naples fl
    cummins or dmax is the way to go. dont waist your time with fords diesels. if you get an lb7 (01-04) make sure its still within the 7 year/200k mile injector warranty.
    01 GMC sclb d-max 2wd.
    2.2 60' 8.9 1/8th
  7. #17
    one word.....powerjoke
  8. #18
    Dec 2005
    Chicago-ish
    If you eat at the drive-through, get the Duramax, you won't have to kill the engine so that they can hear you.
    2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
  9. #19
    naples fl
    i still have to kill it at drive through. but its due to exhaust noise, not injector clank. seriously, in my truck with the radio on i can hear a powerjoke idling from 100ft away. the injector noise is intense on those turds.
    2.2 60' 8.9 1/8th
  10. #20
    Yeah, be careful of buying modded used diesels... I would always look on the driver's sode exhaust manifold to see it it was tapped for an EGT sensor. That is an obvious sign that is was modded....
    Quote Originally Posted by dared2k View Post
    True dat!
    Quote Originally Posted by DuBbLe C View Post
    The older Cummins 12 valve motors make some stupid torque levels! And since they are old tech, with a programmer, lift pump, injectors, etc--they smoke like a damn freight train...
    I am a GM guy through and through--but if it came to an oil burner--I would have to go Cummins!
