Originally Posted by
Madd Maxx
The LS-6 intake valves are 2.00" and the 5.3 valves are 1.89". The exhaust valves are the same size.
The cost to port/polish your heads and install larger valves (if they'll fit) would probably be more than buying the LS-1 heads from Patriot, which would probably flow better.
Plus, if you have true LS-6 valves (sodium filled), they are longer than other LS-series valves, so you'll need shorter push rods.
I would get the Patriot heads and sell off the parts you have - you'd probably be money ahead.
Of course, that's just my opinion and I could be wrong.
Do your due diligence.
