Drivers side exhaust flange with 02 sensor bunge--Free
Water Pump tapped for 1/8 NPT temp sensor,replaced
cause I had a squeak which turned out to be the new belt--$25
Drivers side truck manifold(one broken stud)--$20
Passenger Side Fbody manifold(two broken studs)--$20
Intake tube rubber coupler to TB--$5
A/c compressor bracket with tensioner--$10
EGR gaskets(three of them)--$5 SOLD
Battery postive connection box--$5
Front coolant crossover tube to TB--$10
Exhaust flange gaskets for drivers side(two of them)--$5
#317 heads with lifters and trays and pushrods..last exh manifold bolt hole on one of the heads had a broken bolt...has been drilled out...needs to be taken to a machine shop to repair...was going to do that with 5.3 heads--$50
for faster response email richard.krobot@iongeo.com it goes straight to my Blackberry
Thanks....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[IMG]
[/IMG]
[/IMG]
