Ok
1. $275 was for tools, and I did allot of R&D.
2. The other 2 tubes were not needed. The steamer was replaced with the water seporator, and I found it made more sence to not have a bubbler unless you just HAD to have one. Takes up less space without. The original also did not have a flash arrestor, New one does. Old one had a different coating too.
3. On my truck I drilled and tapped a 1/4 elbow into the intake. Natural vaccuum and pressure from cell is how its drawn in.
I made adjustments to save money, space, and run more effeciantly for yall.
To produce My first kit with all the R&D cost me well over $700 dollars testing different methods. I feel mine is best suited for what it does. And I also had to test stuff like shorts, and long distance to make it safer. I purposely shorted one kit to see how it reacted. I burned up allot of wire.
I guess you could say I was a test rat for yall. And buy letting me build yall kits will save yall coin on doing it yourself.
