Results 11 to 14 of 14
Thread: Garage cleanout sale...buy this crap or it goes in the garbage
Threaded View
    Mar 2006
    Phoenix, AZ
    Any reasonable offer will be considered, I need to get rid of all this crap.
    7 pin round to 4 pin flat trailer wiring adapter. $8 shipped **SOLD**
    Misc assortment of AN and factory style fittings. I don't want to ship these out individually. $40 shipped takes it all.
    (1) -4AN hose end coupler
    (1) -4AN hose end coupler (hose cover only)
    (1) 3/8" pipe to -6AN 90*
    (1) -6AN hose end coupler (hose cover only)
    (1) 3/8" pipe to -6AN straight
    (1) -6AN female to female straight coupler
    (1) -4AN female to male 90*
    (1) -4AN female to female coupler
    (1) 1/8" pipe female to -4AN male 90*
    (3) factory trans-style fittings with clips
    (1) trans cooler in radiator fitting without clip
    (2) clips for factory oil cooler fitting in radiator
    Two lengths of -8AN steel braided line. One is 8ft and one is 15 inches. $35 shipped.
    KC backup floodlights. I had these mounted under my rear bumper for awhile. $20 shipped for lights and brackets. No wiring included.
    Autometer fuel pressure gauge, never used. The included sender works intermittently. Wiring harness has been cut - gauge side is intact with a decent length of wire attached, but sender side is gone. $20 shipped. **SOLD**
    Brake master cylinder and reservoir for a hydroboost truck. $15 shipped.
    Rebuildable truck alternator. Charges but voltage fluctuates. Could be a bad diode or whatever straightens the AC current into DC. I believe it's a 130amp. $40 shipped.
    Wiring harness specifically for a QTP electric cutout. Includes momentary switch, power plug, and connector. $10 shipped. **SOLD**
    Stock coil brackets and heater hose holder. Bolts for coil packs are included. $15 shipped. **SOLD**
    Truck knock sensor harness and one good used knock sensor. $20 shipped. **SOLD**
    Two air filters. Both are 4" ID. $15 each shipped or $25 shipped for the pair.
    Front coolant crossover and rear plugs. $15 shipped. **SOLD**
    Hypertech 180* thermostat for separate housing/t-stat style water pumps. $20 shipped.
    Stock truck oil pan, good shape except for hole drilled and tapped for turbo oil return. Can be plugged easily. $30 shipped. **SOLD**
    Stock headlights for 99-02 Silverado and 99-06 Tahoe and Suburban. $40 shipped. **SOLD**
    TWO electric fans, roughly 12" diameter. I know there are 3 pictured, but one is already promised to a friend. $25 each shipped. **SOLD**
    Stock kick panels from my 01. $15 shipped. **SOLD**
    Stock jack bracket and jack tools clamp from my 01. $15 shipped.
    Stock front and rear driveshafts from my truck ECSB 4wd, along with stock tranny crossmember.
    $40 shipped for front d-shaft
    $40 plus shipping for rear driveshaft **SOLD**
    $30 shipped for crossmember.
    2 stock truck water pumps, pre-05 style with integrated thermostat and housing. $40 each shipped **1 SOLD, 1 LEFT**
    Also have a stock fan clutch, $25 shipped.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
