Hey Alton, Glad everything turned out nice. Get some videos up before you get tazored.
Congrats Alton, Im looking foreward to getting all my front mount stuff finished........![]()
single digit street truck
for build info
Sounds like a sweet setup. I will be joining you guys towards the end of the summer...front mount turbo!![]()
allen n teh crew always do great stuff...
02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
you turbo guys are like a gang! Jeeze, anyway sounds sweet! I know you have waited a long time for this setup, so I am glad to see you finally have what you wanted!
Bryan
The rest of us poor folk will just stick to nitrous I guess!
actually this is my 3rd boosted setupi had to try em all to see how diffrent they are
the first was sts on a 2004 2500ld 4x4...i loved the boost on this truck but the sts kit just wasnt for me in the enviroment in which i work in..here is a vid of it:http://www.ls1truck.com/forums/pics-...l-burnout.html
the next was a 2005 av with a intercooled 112 radix...this ride was awsome!!!!!only draw back was my fault of this kit...i went thru 5 built 65e trannys in this thing because we went all out on the power of this thing with meth and all...was putting down a solid 450 hp and tq after all the mods.anyways instead of going 80e or flt right off the bat i kept rebuilding the 65e and it killed the project after dumping all that money in it for repairs so i made it dissapear....
now to the 2004 excab 2x4 with 4.8....trick turbo...flt level 5 65e and sd tuning ...it ran good but needed more than i could get from the 4.8 so swapped a 6.0,cam,bigger turbo and now im happy again so here we are![]()
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
12 Sec. Club! SOLD
SOLD***
Oh yea, I am still boosted. I had the Exhaust housing on the turbo changed out to have oil and water cooling the housing. I also had an intank pump put in and roller rockers installed. I can push 14 psi now and the fuel should support it. I wont run it that high though.
Jamest
12 Sec. Club! SOLD
SOLD***
