here is a pic of one, compliments of ebay!
might just have to proceed with my custom autometer gauges
89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
Ok, that cluster uses a 2000K pulse and the LS1 4L60E uses a 4000K Pulse. You'll either have to install a dual reluctor ring on the tranny tailshaft like S&P sells for $500.00 or use a Dakota Digital Signal interface with 2000k pulse like this.
Universal Speedometer Signal Interface
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						I did it on my buddy's 89 model when we put the LT1 in it. It's been so long ago that I can't remember how we did it though. It can be done.
[QUOTE=NITROUS;161784]Ok, that cluster uses a 2000K pulse and the LS1 4L60E uses a 4000K Pulse. You'll either have to install a dual reluctor ring on the tranny tailshaft like S&P sells for $500.00 or use a Dakota Digital Signal interface with 2000k pulse like this.
Is the 80ea 4k pulse output also. When I ordered my tune I told them I need the speedo output to be for my stock gauges
Man I sure would like to know how ya'll did it!
 Member
						Member
						I was thinking about doing something like this:
The thing is I don't know if soldering extra wires onto the original VSS wires will foul up the signal or not.
Pete
2002 Chevrolet Silverado
2002 Pontiac Trans Am WS.6
2004 Dodge Ram CCSB Cummins Turbo Diesel
1989 Chevrolet Silverado RCSB - Work Truck, Vortec 454 swap in progress :rocking:
1972 Toyota FJ-40
1963 Chevrolet Corvette Prostreet
The LS1 or truck PCM doesn't put out 2000k so you'll either have to use the DD interface, install dual reluctor rings or mod the PCM which I think there's a DIY forum on Thirdgen.
97 GMC, 2002 LS6.
wtfan18, did the 4000k pulse wire fix your problem?
97 GMC, 2002 LS6.
If you left the wiring to the neutral safety switch like it was originally with the Vortec harness I guarantee the PRND will workon the cluster. I'll see what I can do for you.
97 GMC, 2002 LS6.
