help me pick a 5.3 cam
I'm building a 5.3 for a s10, all the work is done besides the cooling system and engine mods. I have a built 4l60e and 2500 stall, stock internals with 9000 on the clock. I have a set of stage 1 prc 243 heads, and a set of 1.8 ratio roller rockers. I was originally going to put a z06 cam in it but it wont be completly a daily but will be driven 3-5 days a week still. I will be adding a ls6 intake and long tube headers when they come out in a few more months. and I will be adding spray sometime around christmas. I'm looking to have a streetable engine that can go 12s motor and 11 with spray. keep in mind I'm looking for those numbers with a shortbed st cab s10.
a buddy of mine has a 99 camaro ss that puts down 355 to the rear wheels, I want to kill him with this truck if possible.
the cams that I have in mind so far are the comp 216-220 with 525 531 lift, with my 1.8s the lift is .556 .561
also have been hearing alot of good things about tr220's for the 5.3s so i'm looking into them. and have seen up to tr224's in these with good numbers.
if anyone has 5.3 with heads and or more let me know what you have and what power and or times it makes. I'm still learning cam theory and what not I know that the comp i listed and the tr220 are proven 5.3 cams, but I will have more done to my motor then most i've seen with those cams.
thanks
Greg
- You may not post replies
- You may not edit your posts
