Results 11 to 20 of 21
Thread: NGK tr6
  1. #11
    Nov 2006
    Mesquite, TX
    wow that's really rich...lean it out and there is a lot more power there for you....i would go 11.3-11.5
  2. #12
    how do I go about leaning it out a little more? will gapping those ngks to .030 help?
    Nov 2006
    Mesquite, TX
    nope it's in the tune...the colder plugs and gap will allow more timing and keep you safer
  4. #14
    Quote Originally Posted by mean05 View Post
    thats wierd that it started to richen up on me like that. because before I was at the normal 11.2-11.7 range at full boost.
    Nov 2006
    Mesquite, TX
    pleasures of an SD tune...weather changes so will the tune....when i go twins i am keeping the maf...the maf is there to pick up the colder air and the hotter air and will adjust the tune by the air
  6. #16
    what will happen if it stays rich under full boost? will I see changes if any at all if I put those colder plugs in?
    Nov 2006
    Mesquite, TX
    rich is safe so nothing....i was at 9.7 when i put down 519 on the 200 shot...it's just killing power a little bit....running a colder plug you owont notice a difference just you will loose a plug before you loose a piston
  8. #18
    haha OH BOY! should I just stay out of full boost until I get it adjusted? what all will be adjusted? will more timing be added?
    Nov 2006
    Mesquite, TX
    nah keep driving it like you stole it...the only way for it to get more timing and less fuel is through tuning...so your good the way you are...just throw the plugs in it and close the gap up
  10. #20
    alright cool thanks for the help.. ill post up later tonight how it runs when I get the plugs in
