2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
2004 Trailblazer 4.2, K&N CAI, hp tuned
2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
my fault i meant l92. my mistake![]()
G8 GT's have the L76 in them and are running mid to low thirteens STOCK and one tuned by Vector Motorsports ran 13.1@ 107 with no other mods...
Members are also saying STOCK, NO TUNE they are pretty much even w/ SRT8's. The Aussies (Holden Commodore VE-SS) got the LS2's...
The GXP due out late this year is supposed to get the LS3 and six speed man or auto, Manual gets 3.70 rear and the auto gets 3.27 rear....
Can't wait to get one...
13.920 @ 98.94mph...[/b]
L76 is the intake, which you have to have L92 heads, for the L76 to fit. Question is: what is the bore size of the cylinders?
Yeah I know, a cheap copy and paste but I'm lazy...LOL
6.0L V-8 (L76) Application:
G8 GT Type:
6.0L V-8 Displacement (cu in / cc):
364 / 5967 Bore & stroke (in / mm):
3.99 x 3.62 / 101.3 x 92 Block material:
cast aluminum w/ cast-in-place iron bore liners Cylinder head material:
aluminum Valvetrain:
valve-in-head; 2 valves per cylinder; roller lifters Ignition system:
high-energy distributorless ignition; solid state direct-fire ignition w/ coil near plug and integrated ignition Fuel delivery:
returnless, multi-port fuel injection Compression ratio:
10.4:1 Horsepower (hp / kW @ rpm):
362 / 270 @ 5700* Torque (lb-ft / Nm @ rpm):
391 / 530 @ 4400* Recommended fuel:
regular unleaded Maximum engine speed (rpm):
6000
Okay, that compression loss is why it's not 400hp. L92 chambers are bigger than 243's.
And it's tuned to run on regular unleaded...
VMS claims 30+HP and 3MPG increase w/ their tune on 93 octane and that's damn near 400 crank HP...
