Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Transgo HD-2 shift kit... bad???
  1. #11
    Feb 2008
    Arizona
    LOL!!! im glad to hear that from you guys!! i'll go searching around for a good tranny guy!! he told me B&M was the way to go.. good to hear that i made the right decision buying transgo and vette servo... some other guy just told me, they wouldnt improve performance... and that i would hurt my tranny.. but i dont think so..
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
  2. #12
    ff_jeff Guest
    Just make sure that that you put in a pcm that has been tuned for the shift kit and servo. IE> if you have a tune and the shifts have been firmed up, and then you install a shift kit and servos, you will damage the tranny from to harsh of a shift.
  3. #13
    Sep 2006
    Coon Rapids, MN
    Quote Originally Posted by vff_jeff View Post
    I had the HD-2 and loved it just dont have it set up to harsh on the 1-2 shift it will kill the trans. Vince knows his on these trans
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
  4. #14
    Jun 2007
    im with him on that ive done some dealing with flt trans and they know theyre **** .make sure the 1-2 isnt too hard or u will be replacing the tranny ,im on num 6.this time less washers and smaller hole in the sep plate.
  5. #15
    Feb 2005
    San Antonio Tx
    installed the hd2 kit on my tranny when it was slipping 80k on it...
    after the kit i got it up to 134k till I broke the output shaft...
    he's only telling you that so he can get you back in there later on...
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
  6. #16
    The B&m is crap, IMHO. The Trans-go HD2 is more of a complicated kit to install than the Superior. I installed 2 Superior shift kits this past weekend and they were ok to install--I still had to drill out the pressure plate... Bit it is mainly accumulator pistons and springs...
