So how close is CMD A/F to the readings you would get from a wideband?
From my experiance...not very.The pcm is commanding 14.68 but depending on alot of variables it may or may not be rite.IATs,engine load,spark map and other things come into play.I use a narrow band gauge just so i know its not lean at wide open throttle
Vortec Performance Tuned
Now what is a tune again?
Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
See!i stayed awake thru part of the class LOL....thanks use2bfo
wow nice Moze. You should make more videos of your truck, it sounds nice![]()
cant wait for my gauges, in the mail as i type this
very nice, i agree i want to see more vids of the truck
Those gauges are pretty freakin sweet. They will tell you pretty much everything..even if your wife is cheating on you...that effin gauge knows everything!
Oh, and the truck is slow. It doesn't just sound slow, it IS slow. But I'd never try to run you cause it would be a waste of 93, and I wouldn;t wanna hurt your feelings Moze...![]()
