in the SUV and truck market there is almost no solid front diffs being made. especially in GM
2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
My silverado is under 4300lbs. I saw it on the scale at a trash center when I was weighing out after dumping some trash. Mines a 2000 ext z71. And I havent added or taken anything off of it.
mines a 2000 ecsb z71 also with a rollpan and no spare. i should do that, go to the dump and see what i weigh. im not gonna do anything with my 4wd, its worth it too me for the extra traction. i can hardly touch the gas without spining in the rain.
2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
2004 Trailblazer 4.2, K&N CAI, hp tuned
2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
i did this already, each CV axle weighed 18lbs the transfer case weighed 83lbs, front diff weighed 79lbs, and then you have some skid plates and bracing the weighed in the neighbor hood of 40lbs, truck lost a lot of weight and i could feel it pulling better on the top end for sure, but to convert it you need a new trans cross memember and it is easier to get a 2wd trans instead of converting the 4wd one
IMHO, leave it alone. You will want to keep the 4WD capability for offroading and traction at the strip, if needed. I friend told me something a while back when I got my current 2WD truck (I only had 4WD trucks in the past): 4 wheel drive is like a condom. It's better to have it and NOT need it, than to need it and NOT have it...
04 Grand Prix GTP
03 Z71 wanting a Turbo ,Stall, and Tune BAD
THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
true very true
I put my truck on the scale at the track. I'm not sure how accurate it was, but I cant figure out how you ext 4x4 guys weigh less than 5,000 pounds. I should mention, when I weighed my truck it did not have rear seat, tail gate, spare, drop hitch, and front sway bar..
03 2500 HD
05 CBR 1000rr
ECSB 4x frame with torsion bars and 2x drive weighs 5000 without my fat ass.....
