Results 11 to 20 of 33
Thread: Sea Foam Additive!
  1. #11
    SC I put 3/4 in my tank, and its not smoking yet. Well not like yall say its supposed to be at least.
    Apr 2005
    I don't think it will smoke going through the fuel. When you put it in the intake & let it sit, it cleans out all the deposits on heads/pistons/intake.
    Through the tank does the same thing over a longer period of time.
    Gone, but not forgotten!
  3. #13
    Mission, Tx.
    sea foam= i usually suck up 1/3 of a bottle through the vacuum line, pour the rest in the oil, and throw another bottle in a full tank...smoke show for sure. only thing i would make sure and do is change the oil w/ in a 200+- mile range.
  4. #14
    Quote Originally Posted by SCIV View Post
    My intake is brand new, and the top of the heads were pretty clean when I pulled the valve covers. So I should just stick to running it through the gas right?
    Apr 2005
    I would think so.
    You pulled the heads, or the valve covers? You would have to have the heads off to see the pistons/combustion chambers where all the crap is.
  6. #16
    Oh no I just pulled the valve covers.
    Jan 2006
    Put it n the gas, you should be o.k.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
  8. #18
    Like dguerra said, you can put it anywhere, but if you put it on your oil, make sure you put it in RIGHT BEFORE an oil change. SeaFoam is magic...pretty much! Another way to clean out a gasoline motor...fun a SMALL, SMALL amount of diesel fuel in it at idle for about 2-3 minutes. I used this process on all of my mowing equipment back in the day... It was the easiest way to tune up my 4-stroke motors...
  9. #19
    Aug 2006
    Willis, TX
    I bought some yesterday and put it in my tank....feels like I picked up and extra 300 horses....guess now i am at 650 rwhp..LOL
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
  10. #20
    May 2003
    Idabel, OK
    used it many times. Sometimes a very noticable difference, sometimes barely noticable.
    My most recent Seafoam was this weekend and I must say this time yielded the most noticable results ever. I used 3/4 of a can directly into the intake of the noisy rattleing engine in my wife's 4.0 Jeep and 1/4 can in the tank. Let it set all night, drove it the next day, big smoke show, yadda yadda. Man, that stuff made a night and day difference, it runs smooth and seems to have a bit more peep. I am very pleased and will probably follow up with another treatment soon.
    99 C5 cam/boltons 400rwhp
    10 Sierra CC 6.2
    03 Suburban 5.3
