Results 11 to 13 of 13
Thread: 04 GMC Reg.Cab RST 6.0L 400rwhp
Threaded View
    Feb 2006
    Longview, Texas
    I am selling my o4 reg cab rst. The truck was originally a 4.8l with a 5 speed and here is a list of the current modifications. Almost all performance work was done by Allen and Jonathan at Nelson Performance. The truck dynoed 400rwhp on motor alone. The nitrous has only been sprayed to this truck 3 times and that was at the track. The truck ran 12.8 on motor and 11.8 on bottle but that was before the new transmission and 4.10 gears also with the smaller cam that was in it, which personally if i was to keep the truck I planned on putting the smaller cam back in it as the one now is pretty radical, which I will include with the truck if interesed (224/230 .581/.588 114 lsa). The only reason I am selling is I have an 06 gto that I want to do a twin turbo setup on and cant afford to keep both vehicles. As you can see from the pics I have not taken the clutch pedal out yet (not quite sure how it is removed) but it is totally non operational, do not have to push in to crank the truck. The truck itself only has 37,000 miles on it and about 15K on the block, the heads and cam are brand new, maybe 200 miles on them. If you are interested please call me at 903-576-1477 or email at AQK02CHEVY@aol.com. I am asking $21,500 OBO. I have $15,000 in parts alone not including labor.
    LQ4 6.0l
    stage 2 6.0l ported and polished heads from precision race components
    Comp Cam (236/240 duration 602/609 lift on 112+2 lsa
    Comp lifters
    Comp hardened pushrods
    Harland sharp roller rockers
    custom shanner ported throttle body
    44lb injectors
    K&N 77 series cold air kit
    Custom nelson performance tune
    N.O.S. 50 -150 hp wet nitrous kit
    msd window switch
    wide open throttle switch
    Electric fans LS1
    asp underdrive pulley
    Pacesetter coated longtubes with offroad y pipe
    Electric cutout
    Pro built stage 5 4l60E from Finish Line Performance
    3200 precision industries stall converter
    Dual B&M trans coolers
    B&M mega truck shifter w/ nitrous button
    Eaton posi unit
    Richmond 4.10 gears
    Caltrac adjustable traction bars
    Goodmark cowl hood
    Spray in bedliner
    Infinity speakers
    04 regency sport truck with 5 speed lq4 motor stage 2 6.0l heads comp cam .581 .588 224 230 114lsa harland sharp roller rockers shanner ported tb 42lb injectors ls1 fans asp pulley vararam ram air intake nelson tune pacesetter ceramic coated longtubes with offroad y pipe 3.73 gears goodmark cowl hood toyo 295 40 tires
