That is the second time I've heard about the hump. Mine the hump stuck out away from the engine block.
what year are the 15719194 off of?
I am trying to stab my motor and can't get the mounts to line up.
1990 SWB 2000 5.3l 4l60e
It's in just tieing up the loose ends.
They are usually off by about 1/4". What I do is get one bolt in on the driver side and then put my hoist chain to a bolt hole on the driver side and lift just a bit to put a load on the rubber mount. That will give you the alignment for the passenger side hole. Just play around with it for a little bit and all will line up fine.
updated.![]()
