- LS1 Engine w/ Alternator, Starter, Power Steering Pump, Water Pump, Belt, All Wiring and Sensors, and ECU
- T-56 6 Speed Transmission w/shifter
- Dual Electric Fans
- Howe Radiator
o New Radiator Hoses
o Radiator Cap
- Spec Stage 3 Clutch
o Lightweight Option
o Aluminum Flywheel
- Thunder Racing Prothane Polyurethane Transmission Mount
- Open element air filter
- Autometer Gauges
o ATM-4489 5”, 160 mph . . . $199.95
o ATM-4498 10,000 rpm, 5” face . . . $129.95
o ATM-4337 Water Temperature, 100º to 250º F . . . $39.95
o ATM-4327 Oil Pressure, 0-100 psi . . . $53.95
o ATM-4391 Voltmeter 8-18 volts . . .$35.95
o ATM-4314 Fuel Level, most GM after 1965 . . .$35.95
- Fuel Delivery
o AEI-11106 Aeromotive Fuel Pump . . . $292.95
o AEI-12301 Aeromotive Fuel Filter . . .$79.95
o ATM-4363 Fuel Pressure, Full Sweep, 0-100 psi . . .$191.95
o AEI-13101 Aeromotive Fuel Pressure Regulator . . . $135.95
o Custom Fuel Cell
o A Shit-Load of lines I have yet to figure out
- Speartech Wiring Harness
o Graft LS1 harness onto existing TBI Truck Harness (Power, Ignition, Starter, and Fuel) EVERYTHING except for gauges which need to be hooked up to the included Autometer gauges:
 Speedometer
 Tachometer
 Water Temperature
 Oil Pressure
 Voltmeter
 Fuel Level
o Connect check engine light (What do I use in custom dash panel?)
o Left and right turn signals (What do I use in custom dash panel?)
o Parking Brake light
o Shift Light ADDED!
o Connect fan relays + connect to switch provided to be able to turn off fans all together inside cab (What do I use in custom dash panel?)
o 02 Simulators
o Remove all SMOG (Doesn’t have to pass SMOG)
o Wire in electric Throttle Control + all hardware including electric throttle body and pedal
o Wire in ALDO for diagnostics
o Wire in OBDII for diagnostics
Copied this out of word.... sorry for crappy format -- What am I missing? This is for an 88 gmc sierra sbsc, and is going to be my ongoing list until summer when the swap happens. Im sure i'll add more as i think of it like all the part numbers and also the prices.
Brandon
