If your getting that bad of a draw when the fans kick on you probably have a weak battery. I'm not saying it's bad but just week. I'm running underdrives on mine and even at normal driving RPM I only get about 13 volts max of charge. It's normally about 12.5 volts or so and I know exactly what your talking about when the fans kick on. I've seen the load it pulls, both my fans kick on together, but I've never dropped below 12 volts. Get a stronger battery! Anything less than 12 volts is a brown out condition and could cause damage to other electronics.
98 GMC ext cab, 02 LS1, Nelson Tune, S&P headers, cutouts, underdrive pulleys, LS6 intake w/ 85 mm intake, 6/7 drop, 20x10 MB wheels, shift kit w/ servo, 3.42 rear w/ true-trac
