got anymore engine mounts that would fit a 95 gmc sierra for the ls1?
-mike
-mike
will those work on a 5.3 or 6.0? if so how much you want for a set?
Daily driver: '97 Z-71 reg. cab, electric fans, dual bats, K&N cold air, custom built muffler, and your standard blue light special equip...
My Baby: '67 GMC swb small back glass. 388ci stroker, old school bowtie heads est. 450hp, scat steele crank, eagle H beam rods, and Keith Black pistons, but only pushing 10:1 compression, fed by an Edelbrock 750 carb. THM350 trans. shiftkit w/manual valve body, 2800 stall going out back to some highway 3.42 gears, tubbed.
Hello I Am Doing A Ls1 Swap Into A 96 Z71
Do You Still Have Motor Mounts?
I am putting an 2000 ss camaro ls1 in a 96 z71. the motor still has the entire motor mounts on it could i modify those mounts or do you recommend your mounts. I'm looking for the easiest way
yours sounded simple to just bolt them to the motor and weld them to the x-member
oops i am new forgot to look at date
call this place and ask for thier newer design, CAR SHOP LS1GM LS1 LS6 CONVERSION MOTOR MOUNTS ADAPTER PLATES $45.95 BUY ONLINE
their newer design allows the engine to sit back 1" further than the older design.
We just used these on a '92 and the stock manifolds cleared a lot better this time.
Uh ya, the offer to make engine mounts has expired, lol, but these will do the trick!
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
