Page 14 of 19 FirstFirst ... 4 12 13 14 15 16 ... LastLast
Results 131 to 140 of 183
Thread: 6.0 into 98 OBS
  1. #131
    Sep 2009
    NE Ohio
    Here it sits but now I have to separate the motor and trans. I THOUGHT I didnt need the flexplate spacer. But apparently I do. So I used the donor torque converter and now the motor wont turn. I went to put the bolts in the converter and I think it is too tight back there. The flexplate is resting on the back of the block.
    DAMNIT!!!!!! More work and money to spend.
    HELP!!!!!!! PLEASE??????
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  2. #132
    Jan 2014
    Las Cruces NM
    For sure the LS style converter will not work in the older 4l60s. That's all the help I can offer even though you already found that out. Good luck
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
  3. #133
    Sep 2009
    NE Ohio
    I found everywhere there is a flexplate, adapter and bolts needed to bolt the LS to the LT style 60E trans.
    Anyone use this type of setup?
  4. #134
    May 2007
    Medford, OR
    I have a question about the opposite. I have a 2000 LSX 4L60E and TC that I need to bolt to my LT1. Am I going to run into any problems?
  5. #135
    Jan 2014
    Las Cruces NM
    Quote Originally Posted by ccreddell View Post
    The LS style trans has a longer input shaft and won't allow it to bolt up to the older style engines. There may be some work around but I haven't heard of one. You'd be better off selling that one and buying the cheaper older style.
    TURBO IN THE WORKS
  6. #136
    Apr 2014
    They started doing the removable bell housing somewhere in 97. You need the bell housing from a 5.7 97 up.
  7. #137
    Sep 2009
    NE Ohio
    Anyone try to use the OBS throttle body on a GEN 3 motor? I see it fits pretty good. The opening is slightly smaller then the gen 3. I was trying to mount the DBW pedal to the firewall and it is too tight in that area so I am now thinking of using my old throttle body and wire in the TPS and IAC to the PCM and stick to DBC.
  8. #138
    Nov 2013
    Fort Hood, TX (for now)
    Quote Originally Posted by capricefrk013 View Post
    I'd be interested to see the result of this because I am getting ready to pretty much do the same swap. 6.0 LQ9 DBW going into my '98 ECSB. I was a little worried initially about the fitment of the pedal assembly but I've got a friend with a welder and a torch, so I'm sure we can make magic happen!
  9. #139
    Jan 2014
    Las Cruces NM
    It's really not hard at all to get the pedal to fit. I think I was even was able to use the factory holes and bolts. I did cut and weld mine but several others have just bent it to where they wanted it.
    TURBO IN THE WORKS
  10. #140
    Sep 2009
    NE Ohio
    Took a ride down to Summit Racing today and picked up the flex plate adapter and bolts. While I was there I walked through the clearance section and found a cold air intake for a Gen IV 6.0 Silverado for less than half the cost of a new one. I will make it work for my setup.
