 Originally Posted by
kewljay223
				ok man, i gotta ask, how the hell do you keep up on oil changes that often?  i try but damn...  youd have to be checking it constantly to see when it starts to brown...  how many miles do you usually get before do a change?  and when you do change, do you do the filter too or do you change that like every other fluid change since the oil is staying pretty clean?  seems like a lot of work but i gotta hand it to you for staying on top of that....
  I'm always puttering with the truck anyway. Checking for leaks, etc.. While the hood's up, I check the oil. I have roughly 6500 miles since the swap and I've changed the oil and filter 3 times.
As for how long it goes before getting brown, I guess that would depend on how clean the engine is inside. The only cover I pulled the was the rear main seal cover to replace the seal. By the looks from there, the engine was fairly clean inside(relatively speaking) considering it had 140,000 on it when it went in. I guess I get around 2000 or so miles before it's getting brown enough to change.
			'93 Chevy 1500 4X4 ECLB with a '99 Silverado LQ4 6.0 and '99 Escalade 4L60E.     SOLD IT!!
John
