Page 13 of 19 FirstFirst ... 3 11 12 13 14 15 ... LastLast
Results 121 to 130 of 183
Thread: 6.0 into 98 OBS
  1. #121
    Sep 2009
    NE Ohio
    Quote Originally Posted by Lextech View Post
    I have never seen a Drive By Cable throttle body with a 6 wire T.P.S. OR Are you meaning you want to use 3 of the existing DBW wires to connect the T.P.S. to the PCM?
    Jeff
    Correct about using a 3 wire TPS to PCM if I change to a DBC throttle body.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  2. #122
    May 2007
    Oak Forest, Illinois
    You will need 3 wires for the T.P.S. and 4 for the I.A.C. Let me look it up tomorrow---It's bedtime.
    Jeff
    98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
  3. #123
    Sep 2009
    NE Ohio
    Sounds Good. Thanks Jeff.
  4. #124
    May 2007
    For the T.P.S.
    Gray wire to PCM C1-8
    Dk.Blue wire to PCM C2-24
    Black wire to PCM C1-60
    For the I.A.C.
    Lt.Green/White wire to PCM C2-76
    Lt.Green/Black wire to PCM C2-77
    Lt.Blue/Black wire to PCM C2-78
    Lt.Blue/White wire to PCM C2-79
    Jeff
  5. #125
    Sep 2009
    NE Ohio
    For the T.P.S.
    For the I.A.C.
    Jeff
    Thank You for the info.
    On my pinout diagram for the PCM, C1-8 & C2-24 are not used and the C1-60 has an orange/black low reference. Does something have to be activated in a tune for the not used locations or it will work regardless?
    Thanks
    Dennis
  6. #126
    Sep 2009
    NE Ohio
    I got the DBW problem worked out. I forgot to label the pins for the TAC motor and never pinned them back in to the TAC Module. I now have throttle.
    https://www.youtube.com/watch?v=6s328tX0ulM
  7. #127
    May 2007
    Quote Originally Posted by capricefrk013 View Post
    C1-8 and C2-24 aren't used on yours because you have a DBW harness. Remove the wire from C1-60 and don't use it. It is a low reference for a secondary fuel sending unit. It will be the low reference for the TPS now.
    You need to run 7 wires from the I.A.C. and T.P.S. to the PCM and flash the PCM with a DBC calibration.
    Jeff
  8. #128
    Jan 2014
    Las Cruces NM
    If only they would stay that responsive after bolting all the stuff on. Sounds good, glad you got it all worked out. I think you'll be happy with the dbw. I was a little worried when I chose to stay with the dbw but now am really glad I did.
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
  9. #129
    Sep 2009
    NE Ohio
    Jeff
    I will keep this in mind if I decide to change it later. But since I got it all worked out I think I will keep going this route. Thank you for your help and knowledge.
    Quote Originally Posted by Chevydillan View Post
    I hear the DBW can be tuned to become more responsive. I will have to talk to my tuner about that when I get it stabbed in the truck and start driving it.
  10. #130
    Sep 2009
    NE Ohio
    Finally started my swap tonight. I hope to have it in and running by this weekend. I am doing at work and in between jobs. Tomorrow is my day off and I hope to get the old motor out and new one set in so I can push it over to my bay and get started on the wiring. Once that is done I will push back on to a lift and do the exhaust.
    Im still up in the air about how I will do the exhaust. I want to do 3" and maybe bend it to go out the back like factory. I will be cutting the cat out of it and weld on the heat shields, I have to be able to pass emissions and they check for the cat. My dad has done the same ting on all his trucks and never had an issue.
    Pics to follow as I go along.
