Page 13 of 13 FirstFirst ... 3 11 12 13
Results 121 to 130 of 130
Thread: 01 Silverado LS1 / T56 conversion
    Mar 2004
    Originally posted by Ron+Oct 3 2004, 08:53 AM--><div class='quotetop'>QUOTE(Ron &#064; Oct 3 2004, 08:53 AM)</div>
    <!--QuoteBegin-retsell
    @Oct 2 2004, 03:11 PM
    Well, I have all the parts for my t-56 conversion except for the tranny itself and shifter. I have:
    Clutch pedal
    02 truck master cyl
    02 truck slave cyl
    02 fbody slave cyl
    bellhousing
    ls6 clutch, flywheel
    arp flywheel bolts
    gm pressure plate bolts
    A couple of questions:
    What kind of hardware mounts the clutch pedal assymbly in? It has a hole in the top, and two on the firewall side, and my truck has a metal bracket on the firewall with 2 holes. I am planning on just using a few nuts and bolts, but I would like to use oem style hardware.
    The truck slave doesn&#39;t appear to work with the t-56. The fbody slave is about 2 inchess smaller in diameter and the bolt holes are much closer together. Also, the truck slave has a smaller hole in the center of it for the input shaft. What year slave did you use Ron???
    I don&#39;t want to have to rob the line off the truck slave to use the fbody if I don&#39;t have two b/c I paid 130 for it from the stealership and would like to return it.
    I guess I still need to pick up the bolts to bolt the bellhousing to the tranny.
    Any ideas guys?
    My Truck is an 01 model and the I used the slave out of that on my T56. I ordered an 02 F body slave thinking that might be better but they were the exact same part number. My T56 came out of a 2000 T/A so there may be some differences in the years of the transmissions as far as slaves are concerned. [/b]
    Do you think a replacement 01 truck slave would have the hydraulic line with it?
    2002 GMC Sierra ECSB 5.3
    Richmond 4.56 Gears
    Auburn Posi
    Radix Blown
    2.75" Pulley
    Nelson Tune
    HPTuners w/ Enhanced I/O
    3" Dynomax Superturbo (no cats) w/ QTP E-Cut-out
    160* Thermostat
    Big MOFO Heat Exchanger
    TOG Titanium Coated Headers
    T56 6 Speed Conversion
    Spec Stage 3 Clutch
    Pro 5.0 Shifter
    Jun 2003
    North Central Arkansas, Cave City
    It probably would
    http://img.photobucket.com/albums/v6...nstruckls1.jpg
    05 Joe Gibbs RCSB 5 gear
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    May 2004
    Pickerington, Ohio
    Do you guys have any extra parts? I need more than just this T56 in the garage.
    2007c CCSB 2wd lowered 2/2 Stock!
    2002 RCSB 2wd H/C 5.3l T56
    LQ4, 243, 228R, Holley Hi Ram, 4L80e, 4.56 - in the works!
    Jun 2003
    I have a good master cylinder. I bought a new one thinking this one wasn&#39;t working like it should but it worked the same. I take &#036;35 + &#036;7.50 shipping.
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    May 2004
    Pickerington, Ohio
    Sent you an email&#33;
    Austin, TX
    So what was the total length of the new driveshaft ? And how much did it set you back if you dont mind sharing.
    Marc
    Red 94 GMC Sonoma
    Red 94 Jeep Wrangler
    Red 02 RCSB Silverado
    Red 03 Ford Cobra
    Red 04 CC Silverado
    Red 05 Yamaha Raptor
    I really like red
    Jun 2003
    Marc
    Driveshaft came from Denny&#39;s, 61 5/8" was the measurement from the back of the trans case to the face of the pinion yoke, &#036;495.95 shipped
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Jun 2003
    Went to the Dyno today and was pleased but I will post in the Dyno Data Section so we can keep all our numbers in the same place
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Mar 2010
    San Antonio, Tx
    Does anyone know the steps and parts I would need for converting a 2002 5.3 2WD ECSB 4L60E to a T56? I hate automatics and already blew it once.
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
    Congratulations, you dug up a 6 year old thread
