Well, I have all the parts for my t-56 conversion except for the tranny itself and shifter. I have:
Clutch pedal
02 truck master cyl
02 truck slave cyl
02 fbody slave cyl
bellhousing
ls6 clutch, flywheel
arp flywheel bolts
gm pressure plate bolts
A couple of questions:
What kind of hardware mounts the clutch pedal assymbly in? It has a hole in the top, and two on the firewall side, and my truck has a metal bracket on the firewall with 2 holes. I am planning on just using a few nuts and bolts, but I would like to use oem style hardware.
The truck slave doesn't appear to work with the t-56. The fbody slave is about 2 inchess smaller in diameter and the bolt holes are much closer together. Also, the truck slave has a smaller hole in the center of it for the input shaft. What year slave did you use Ron???
I don't want to have to rob the line off the truck slave to use the fbody if I don't have two b/c I paid 130 for it from the stealership and would like to return it.
I guess I still need to pick up the bolts to bolt the bellhousing to the tranny.
Any ideas guys?
2002 GMC Sierra ECSB 5.3
Richmond 4.56 Gears
Auburn Posi
Radix Blown
2.75" Pulley
Nelson Tune
HPTuners w/ Enhanced I/O
3" Dynomax Superturbo (no cats) w/ QTP E-Cut-out
160* Thermostat
Big MOFO Heat Exchanger
TOG Titanium Coated Headers
T56 6 Speed Conversion
Spec Stage 3 Clutch
Pro 5.0 Shifter
