Page 11 of 17 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 101 to 110 of 162
Thread: Time to get started 4.8 to 5.3
  1. #101
    San Antonio, TX
    Post up some pics of the vac hoses and where they are routed?
    also, check the back of the charger, there are a few ports back there.
  2. #102
    Feb 2009
    Quality KY.
    Three lines back there. Brake Booster PVC and one that goes to the black valve on the side of the blower the valve with the yellow sticker on it. I put the air line into the brake booster line to feed air in to see if I had any leaks. All were good.
  3. #103
    Feb 2009
    Quality KY.
    I am like you keep thinking air but for the life of me I can not find it. Way is every PCM coming up with a different code?
  4. #104
    Pittsburgh, PA
    get a Benz-o-matic torch. start the truck and let it idle. open the nozzle on the torch but dont light it. now go around entire intake manifold and tb and any vaccum port with this. if the RPMs change then you sir have a leak
    also you should be able to hear such a huge vaccum leak if indeed you have a vaccum leak
    is it possible your throttle cable is bind'd up and is allowing the TB to be open?
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  5. #105
    Feb 2009
    Quality KY.
    TB cable is free. Benz-o-matic torch is one I never herd
  6. #106
    Augusta, Ks
    Ive aways heard brake clean or carb cleaner.
    2004 Buell XB12s
  7. #107
    Pittsburgh, PA
    Quote Originally Posted by WARLOCK View Post
    never a fan of spraying a flamable liquid on a hot running motor
    412 Motorsports
  8. #108
    Feb 2009
    Quality KY.
    Did the brake cleaner and carb just did the Benz-o-matic torch no change in idle. Pulled the brake booster line of and plugged it to see if there was a leak there no good.
  9. #109
    Pittsburgh, PA
    for shits and giggles. remove the throttle cable off the throttle blade totally. start truck up see if it idles normal
    also is your IAC leaking air ?
    412 Motorsports
  10. #110
    Feb 2009
    Quality KY.
    Did not help. IAC is new. Put my finger up in there were the IAC goes from the inside of the TB and it seems to be setting. Going back out and try something. It has pulled two quarts of oil through it so I am thinking the PVC may be stuck open. One letting it pull oil out two letting air in all the time and may be my leak. And that is the only line I have not pulled today. Back at it
