Page 10 of 13 FirstFirst ... 8 9 10 11 12 ... LastLast
Results 91 to 100 of 130
Thread: 01 Silverado LS1 / T56 conversion
    Jun 2003
    North Central Arkansas, Cave City
    Console
    http://img.photobucket.com/albums/v6...nstruckls1.jpg
    05 Joe Gibbs RCSB 5 gear
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Jun 2003
    Console
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Jun 2003
    Cluster
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Aug 2004
    atlanta
    Damn that console looks great, and it looks like something factory only better.
    Mar 2004
    I am working on this swap as well, but from a 4l60e in an o2 gmc.
    I heard the driveshaft will work with going from the 4l60 to the M6, so I am not worried about that.
    Did you use your stock clutch master cylinder? Did it work out ok with using the t56 slave cylinder? No release problems or pedal sticking to the floor??
    Did you use your stock hydralic line between the master and slave cylinder?
    2002 GMC Sierra ECSB 5.3
    Richmond 4.56 Gears
    Auburn Posi
    Radix Blown
    2.75" Pulley
    Nelson Tune
    HPTuners w/ Enhanced I/O
    3" Dynomax Superturbo (no cats) w/ QTP E-Cut-out
    160* Thermostat
    Big MOFO Heat Exchanger
    TOG Titanium Coated Headers
    T56 6 Speed Conversion
    Spec Stage 3 Clutch
    Pro 5.0 Shifter
    Jun 2003
    I used all stock items except I used a SPEC II clutch. The slave in the T56 was the same as the one in my 5 speed. Everything works fine
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Aug 2004
    atlanta
    Ron is it true you can stick a t56 behind the 4.8. If so what else besides the driveshaft would have to be change out?
    Mar 2004
    if you go from auto to t-56 you do not need a new crossmember,
    you need
    clutch
    flywheel
    tranny
    bellhousing
    master cyl
    slave cyl
    pilot bearing
    hydro line
    pedal assym.
    flywheel bolts
    pressure plate bolts
    clutch pedal bolts
    shifter
    shifter handle
    reprogram ecu
    modify crossmember
    I dont think im forgetting anything
    remember, the ls1 block and 4.8, 5.3, 6.0 block are all almost identical on the outside. A couple of accessory bolt holes are missing between the two, but thats it. 99.99999 percent of all parts are interchangeable, including trannys.
    Richmond 4.56 Gears
    Auburn Posi
    Radix Blown
    2.75" Pulley
    Nelson Tune
    160* Thermostat
    Spec Stage 3 Clutch
    Pro 5.0 Shifter
    Aug 2004
    atlanta
    Got the 5spd does that take off some of those needed things?? That's a hell of a nice list to thanks!!
    Jun 2003
    If you already have a 5 speed it make it pretty easy, about the only thing you would need would be a shorter driveshaft, most T56's come with bellhousings and if they are out of a Camaro or T/A they will bolt up fine. The T56 and your 5 speed use the exact same slave cylinder so you can use your truck slave which has the hydraulic line attached or you can use the T56 slave and drive the roll pin out and swap in the truck hydraulic line. And also you will need a set of 4.56 gears.
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
