Results 1 to 10 of 12
Thread: whippled LQ4 cam ideas
    91_bowtie Guest
    I have a lifter sticking, so I'm taking this as a sign to get a lq4 ready to drop in its place. Right now, I'm running a 220/224 .564/.567 on a 115+2 LSA, and it seems to work very well with my combo. I know the bigger motor is going to want more cam, but I don't want to overdo it. I have a yank TT2600, but I'll have a PI 3000, 3 disk, by the time the new motor is ready. I'm also running 3.73 gears with 28" tires. The whipple is now making 10 psi. Everyone has good results with the GT2-3, but I've gotten great results from the current cam, and its going to take some convincing to get me to switch to something very different. Do you guys have any suggestions for me?
    Sep 2004
    <div class='quotetop'>QUOTE(91_bowtie &#064; Jan 14 2007, 12&#58;00 AM) [snapback]79711[/snapback]</div>
    I have a lifter sticking, so I&#39;m taking this as a sign to get a lq4 ready to drop in its place. Right now, I&#39;m running a 220/224 .564/.567 on a 115+2 LSA, and it seems to work very well with my combo. I know the bigger motor is going to want more cam, but I don&#39;t want to overdo it. I have a yank TT2600, but I&#39;ll have a PI 3000, 3 disk, by the time the new motor is ready. I&#39;m also running 3.73 gears with 28" tires. The whipple is now making 10 psi. Everyone has good results with the GT2-3, but I&#39;ve gotten great results from the current cam, and its going to take some convincing to get me to switch to something very different. Do you guys have any suggestions for me?
    You are more advanced than I am. I&#39;m running a much smaller cam than you are and considerably less boost.
    I&#39;m about to put in a Z06 cam to see if I like it better. Keep us informed on how your combo works&#33;
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    91_bowtie Guest
    It&#39;ll probably be a couple months, but I&#39;ll post an update.
    Apr 2003
    Mansfield, Texas, USA
    You&#39;re not really going to gain much with a larger cam, the truck intake is a limit on top RPM power. The SSR intake would help a bit but I don&#39;t think you should spend cash for another camshaft grind.
    Torque is what will propel you and what you need in that tank.
    91_bowtie Guest
    <div class='quotetop'>QUOTE(Hit Man X &#064; Jan 14 2007, 11&#58;47 PM) [snapback]79803[/snapback]</div>
    I don&#39;t want to waste money, but I don&#39;t want to half@ss it at the same time. I&#39;m just wondering if a bigger split would be better for me? I&#39;d also like to see more neg overlap. I never saw a cam card for this grind. I was just given the specs from the previous owner. Its still a question whether its a true 115 or the 115+2.
    I&#39;m running the smallest pulley whipple makes, and only seeing 10psi with no belt slip. Others are seeing 12+ with this setup, and 2.5" duals. I&#39;d think my single 3" would be a little more restrictive, but I wanted it for the torque and stock appearance. This cam also has a noticeable lope, while idling around 700. All of this leads me to believe the cam is bleeding off some boost. Now that I&#39;m starting out fresh with a new motor, I&#39;d like to do it right. If that means using the same cam.. great; but if not, I&#39;m prepared.
    Apr 2003
    Cool
    CarCraft had a huge article about a year back about boost and nitrous cams, unless you&#39;re making HUGE power they didnt do much of anything. Surprised me too. Widening the split can result in more negative overlap, I posted the math up on GMFS a while back. I THINK it is:
    Add durations, divide by four. Subtract LSA, multiply by two.
    Single 3" is certainly hurting you. You could always go 2.5" duals into a 4" Y-pipe. 3" duals may be a tad overkill but I dont know what your total goals are...
    With 10-12psi you shouldn&#39;t have any torque issues.
    91_bowtie Guest
    <div class='quotetop'>QUOTE(Hit Man X &#064; Jan 15 2007, 01&#58;27 AM) [snapback]79808[/snapback]</div>
    hmm.. the cams I was looking at don&#39;t provide that much more neg overlap than I already have.
    I knew the exhaust was holding me back up top. I&#39;ve been considering a single 4". I already have a nice custom 2.5" y-pipe. I&#39;m just going to drop the rebuilt 6.0 in and spray at the most a 150 shot.
    Apr 2003
    Cool
    You have headers I&#39;m sure... right? lol You could do 3" y-pipe and a single 4".
    That&#39;s a LOT of cylinder pressure you&#39;re talkin about with 150hp MORE from the juice. You&#39;re going to be in the 700-800tq range at the flexplate, pay attention to the rest of the driveline.
    Do you have meth injection yet?
    91_bowtie Guest
    <div class='quotetop'>QUOTE(Hit Man X &#064; Jan 15 2007, 01&#58;57 AM) [snapback]79815[/snapback]</div>
    pacesetter&#39;s
    I think an 80e is in my future.
    hell yeah. I wouldn&#39;t be at 10psi without it. I have the Snow stage 2 kit.
    Apr 2003
    Cool
    <div class='quotetop'>QUOTE(91_bowtie &#064; Jan 15 2007, 02&#58;05 AM) [snapback]79817[/snapback]</div>
    pacesetter&#39;s
    Hell, you could just modify the Pacesetter y-pipe to uncork it more up front. Magnaflow has a 4" in/dual 2.5" out from my memory.
    I&#39;d be more concerned about all the heft (6500lbs?) and that 10bolt junk. 9.5" SF is an EZ swap...
    Okay cool, that&#39;s the same kit that&#39;s going on the running BMW @ 17psi.
