Has anyone used impala efans? I have them and they work great. Best of all, they cost $91 and $30 to install. Alot of people here in the RGV have these. You don't to modify anything.
03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
13' Sierra Denali 2500HD CCSB 4x4
<div class='quotetop'>QUOTE(graysilverado5.3 @ Oct 10 2006, 03:44 PM) [snapback]68697[/snapback]</div>WHAT YEAR ARE THE FANS FROM THE IMPALA? WHAT ARE THE DIMENSIONS? I AM LOOKING FOR SOME E-FANS FOR MY 3/4 TON 2000 SIL. I NEED HEAVY DUTY COOLING.Has anyone used impala efans? I have them and they work great. Best of all, they cost $91 and $30 to install. Alot of people here in the RGV have these. You don't to modify anything.
JAMEST
12 Sec. Club! SOLD
SOLD***
The fans are for like a 2000 impala. There double fans. I don't know about a 3/4 ton but my truck likes them. I have a 28" radiator and they fit perfect on mine.
<div class='quotetop'>QUOTE(graysilverado5.3 @ Oct 10 2006, 06:38 PM) [snapback]68725[/snapback]</div>The fans are for like a 2000 impala. There double fans. I don't know about a 3/4 ton but my truck likes them. I have a 28" radiator and they fit perfect on mine.
Yep, I helped put a cam in a white swb/rc truck there in The Valley (McAllen) and he had those Impala fans. They really look like they belong there. Definitely a cheaper route compared to the aftermarket offerings.
I bought a pair of used 16" fans for my Ford EFI 460, but havent put them on yet.
99 C5 cam/boltons 400rwhp
10 Sierra CC 6.2
03 Suburban 5.3
<div class='quotetop'>QUOTE(graysilverado5.3 @ Oct 10 2006, 06:38 PM) [snapback]68725[/snapback]</div>I THINK IM OUT I HAVE A 32 INCH RADIATOR.The fans are for like a 2000 impala. There double fans. I don't know about a 3/4 ton but my truck likes them. I have a 28" radiator and they fit perfect on mine.
THANKS,
JAMEST
12 Sec. Club! SOLD
SOLD***
<div class='quotetop'>QUOTE(Jamest @ Oct 11 2006, 09:47 AM) [snapback]68820[/snapback]</div>Me TooI THINK IM OUT I HAVE A 32 INCH RADIATOR.
THANKS,
JAMEST
[/b]![]()
Does the nelson harness work on the Impala fans? And where'd you get 'em for $91
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
I don't know if that harness will work. I'll try and get some pic's so that you all can see. My fans are always turned on high. Both are always on.
<div class='quotetop'>QUOTE(graysilverado5.3 @ Oct 10 2006, 09:37 PM) [snapback]68762[/snapback]</div>How did you wire them in?I don't know if that harness will work. I'll try and get some pic's so that you all can see. My fans are always turned on high. Both are always on.
Can't get the pic's to work![]()
