pulled the trigger on a 2001 lq4 over the weekend to swap into my 96 chevy k1500. i am still on the hunt for a 4l80e and manual T-Case to put behind it. i do not think my 4l60e will last long behind the 6.0 and also my truck has the push button 4wd now, which i hate. so figured i would kill two birds with one stone and find a 4l80e with manual tcase out of a junkyard or wrecked truck or something. shouldnt be too hard to find around here.
motor is complete with harness, ECM, and fuse box and other misc parts. my plan for the motor is heads/cam, headstuds, trunion upgrade, springs, ls3 timing chain and oil pump, longtubes, and a tune. i would like a bump in compression so i was thinking of looking for a set of 243's (has 317's now), but if anyone has any other suggestions i am all ears! not really sure what cam i want to go with yet, not sure if i should look for an off the shell cam or get something custom speced for my setup. for the harness i am thinking of using my black box PCM as a BCM and then using the 411 with a stand alone harness to control the lq4/4l80e. since my truck is a 96, i shouldnt have to upgrade the fuel pump, but will need to run new AN lines from the fuel filter to the rails. also planning on using 4th gen f-body fans as well.
i dont really care about a/c. the a/c on my truck has been broken since i bought it (had it for almost 4 years) and could probably count on two hands the amount of times i have wanted it. could never justify spending the money on a new compressor and condensor to get it working so i am not really worried about that. i will probably go with the dirty dingo motor plaes since it will allow me to position the motor where i want (hopefully can reuse the stock DS) and they will bolt up to the factory chassis mounts. longtubes are my biggest roadblock so far, i think pacesetter makes something but have to check on that. was really hoping for stainless since this will be driven in the winter (its my daily) so that would be optimal. going to have to do some research for that.
the truck already has a 6 lug 14 bolt rear end that i swapped into it earlier this year and i have a trutrac with new 373 gears waiting to go in the axle as well. so i am not worried about blowing up the stock 10 bolt (already did that with the factory motor lol)
here is the truck that i will be swapping...
here is the motor when i got it home...
this is my daily driver, but the weather is finally getting nice so i will be able to drive my camaro while i do the swap.
if anyone has any suggestions or comments feel free to post em, im sure i will have a lot of questions once this starts going. i am going to keep track of progress in this thread and one on ls1tech forum as well.
also, in the last picture, there is no threaded bellhousing hole to the right of the top hole, is that normal??? seems to me that there should be one there.
