I swapped in a 5.3 in my obs
I used a PSI wiring harness with the swap
I hooked the tach wire from wiring harness to the white wire on firewall connector ( c100)
Can someone help diagnose why the tach isnt working?
Been lurking since 09 and I finally have my kickass 6.0 LQ4LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
Wow thanks. I just bought the resistor. So what is the fix?
97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
TURBO IN THE WORKS
I found it once but I cant remember where I saw it. I cant remember if it is in the tune that can fix it or not. If I remember correctly, because I cant find it on my computer. I dont need it for my truck being a 98. I think it was just the earlier ones. I could be way off though. I am still searching for a solution.
You most likely need to change a parameter in the tune . Here is a snap shot from hptuners. The tach resolution needs to be changed to make your tach work. My high and low resolution are set to 3 for mine to work correctly.
Here's what I did
Tach can be seen in operation here.
www.youtube.com/watch?v=8pqNuuCdePI
95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
That's what I posted just with a 680 ohm resistor instead of 1000.
Thanks I'll try this one.
TURBO IN THE WORKS
What is the difference in the resistors
Besides the 320ohm difference nothing. I think either resister should work just fine I'm going to go ahead and try my 1000ohm this weekend I'll let you know how it works out
TURBO IN THE WORKS
