FS: 2004 Silverado Crew Cab
Well the time has come for me to sell my beloved truck. I'm picking up a 2014 crew cab with a 6.2 this weekend! The 2004 comes with everything listed in my sig. The truck has 125k miles on it and the built motor has approximately 50k miles on it with most of it being just to and from work each day. I'm asking $9,000 for it. Please send me a PM with any questions.
The motor:
Bored 5.3 block to a 5.7 with Probe forged pistons
317 heads with Patriot Dual Gold valve springs
Comp chromoly push rods
Comp cam Stealth Cam 220/220 581/581 115lsa
Vic Jr intake
Siemens 60lb injectors
Walbro 255lph fuel pump
ARP head bolts
LS1 efans
4 core radiator
Revextreme Catch Can
Only ran Royal Purple 15w40 synthetic and changed the oil every 5k miles
Trans
FLT Level 7 trans with billet input and output shafts
Yank TT3000 converter
Eaton Posi with 3.42
Tru Cool 40k trans cooler
Just had a full service trans job done and converter refreshed. Shifts strong and bands and clutches looked brand new.
Turbo
STS system with Master Power T-76 .96a/r
FMIC
50mm Tial BOV
STS boost controller
Snow meth kit with large tank, progressive controller and low level indicator
Tires
Michelin LTX M/S 255/70R16
Rears 70% tread remaining
Fronts 90% tread remaining
Other
Aeroforce scan gauge
Autometer boost
PLX wideband
Line lock
(2) Mickey Thompson ET streets mounted on stock wheels (10 passes)
SS Gauges (installed) and stock gauge cluster will come with
Items of note
The windshield has a crack in it on the passenger side
There is a scratch in the rear quarter panel just behind the wheel well approximately 12" - 18" in length
Radio display only works sometimes. Radio itself works fine.(stock unit)
Basics
A/C and heat work great
Power windows and locks
I am the only owner and it was always garage kept
Non-smoker
Clear title
Never been in an accident
Best pass
Time slip
- You may not post replies
- You may not edit your posts
