Fuel Pump continuously running after swap. Help!
Ok to make a long story short I just got my 5.3 swap into my 92 obs running. The only problem is that I cant figure out why the fuel pump stays on all the time. I didnt modify the stock fuel pump wiring besides splicing in the new walbro pump plug and running the fuel pump wire to the oem fuel pump relay(green wire with white stripe). And the wire from the new ecu is working correctly. It sends 12v for 2 sec to prime before startup, i checked. But even so, the fuel pump continues to run even with the key off. It will also continue to run with the fuel pump relay disconnected...wtf? Only way to kill it is to pull the fuel pump fuse. And another weird thing is that sometimes it will work properly out of the blue. After the first 2 sec. The fuel pump will stop and will only continue when i crankthe engine. Any idea what is causing this? The grey fuel pump wire ties into a bunch of other stuff and the diagram doesnt make much sense
- You may not post replies
- You may not edit your posts
