Results 1 to 10 of 12
Thread: RAS or Traction Bars
    Apr 2012
    LaVista Ne.
    Has anybody tried RAS (Roadmaster Active Suspension) I don't haul or pull a trailer. I'm debating between the RAS and the Cognito Traction Bars. The truck dose have a 6in lift. Here is a link to RAS.
    http://www.activesuspension.com/eliminate-axle-wrap-2/
    Jan 2012
    Anacoco, La
    If you don't haul a trailer why would you wanna put helper/ overload springs on? Going to make the ride rough in the back to. Do the cal tracs. Not sure what springs came with your lift but I don't have any axle hop with mine. May be shock issue also. I'm using pro comp 9000, and 33in pro comp Xtream MTs with a Tru trac and they just spin and smoke lol
    Apr 2012
    LaVista Ne.
    Here is my thought. I'm getting the motor rebuild to a 383. I going to build the trans myself. (Monster in box). That's going to be an experience in its own. I'm more worried about axle wrap. Just want to keep thing from inline with the extra torque. I run Dick Cepek 35 Mud Country. I just in stalled new Fox shock also. I also added a E-Locker this year.
    Arizona/Utah
    The monster in a box is a good option if you do it right. Not the very strongest out there, but a complete kit for sure. Caltracs or similar will help a ton with axle wrap. It's a great mod especially for the money.
    Aug 2005
    St. Anthony, Indiana
    If you switch to lift springs instead of the lift block, that will take care of the axle wrap issues. That is what I run.
    Apr 2012
    LaVista Ne.
    Foggy: Were did you get your springs. I think that may a very good option to consider. The lift I have is BDS 6'.5" Lift with blocks.
    Jan 2012
    Anacoco, La
    Is there diff springs on the half ton z71s depending on the package? Mine are pretty stiff and I'v never had a wheel hop prob. But I know guys that have and there trucks squat easyr than mine. Idk may be something to look into
    Aug 2005
    BDS sells the lift springs also.
    Hey, I was reading about suspension upgrades and ended up comparing traction bars and other mods for my truck. After that, I took a break and found aviator app , which immediately stood out because it offers special bonuses for players from Nigeria. I decided to try the Aviator game, and after losing a few rounds, I raised my bet and finally landed a solid win that made the evening exciting. The whole experience felt smooth and fair, and it was a great way to relax after digging through all that technical stuff. Definitely worth checking out for some casino fun.
