Results 1 to 10 of 17
Thread: To VVT or not to VVT
    Sep 2010
    North East Ohio
    I think I'm going to get a different cam soon. Instead of dealing with a hydroboost conversion and getting a bigger stall so my truck actually gets its bottom end grunt/ vacuum back I think I may just change the cam and get something a bit smaller. Current specs are 219/228 .550/.550 114. Been talking to Comp cams and they recommend a VVT cam sized at 210/224 .556/.568 114 for my application. The new cam is listed from 1300-6500 in their catalog and the closest one they have to my current one is 219/235 with 113 LSA which they list RPM range of 1500-6700. I just don't want to go through all the work again and still have similar characteristics. I have also thinking about ditching the VVT since I could almost do it for the same price and get a custom single bolt grind like the 212/216 in a single bolt ? Name of the game on this one is as much useable street friendly torque possible.
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
    Arizona/Utah
    Ditch the vvt if you switch cams but I would keep the cam you have and therefore keep the vvt. Did you swap up gears yet? That cam is also begging to be sprayed.
    Couldnt agree more!!!
    SHIFT
    Sep 2010
    North East Ohio
    I have not done the gears yet. I drive a ton of highway driving so I have been putting it off. I'm looking at the 210 / 224 vvt cam that comp is offering. Moves everything lower but there is not a hole lot of info on it. I talk to comp and they can do any of their cams even the 212/218 on a vvt core.... If I take back back the front and rear gears I can get the new cam and nitrous for a even exchange...
    Cam, Stall, 4.88's
    Sep 2010
    North East Ohio
    Just to give you an idea how much lag there is. We had a fresh rain here today and it would not spin after trying several times. It is a VVT cam and I dont think its to big but I think its actually the "early style" core which would put it 14 degrees retard on centerline the entire RPM range. There was no way to know so it was a trial and error type of deal. I think if I get the right grind in there the truck will haul... that comp vvt cam I was looking at 210/224 I think has a good duration for having some low grunt to it. I even considered the 208/212 custom ground with a 112 lsa vs he 115 to give it the "sound" of my current cam.
    Cam, Stall, 4.88's
    Arizona/Utah
    Another issue to keep in mind is that the 4.8 will never have gobs of torque. It needs the gears to be truly happy. It is one of the very best mods out there! A different cam isn't going to make the huge difference you are looking for. Either ditch the VVT or keep the cam. VVT sucks!!!!
    His current cam is vvt style so he can't ditch it the vvt and keep the cam.
    Nov 2009
    SAN ANTONE
    Not VVT sucks
    Feb 2012
    Dallas
    dude i loved my vvt and got good MPGs and HP out of mine when i had it as my daily
    If you can give me a little bit, I'll give you a list of part numbers. I retained a single bolt cam but did remove vvt.
