5.3 mild cam for dd. need advice for the rest of the parts needed
I'm finally ready to order parts. I decided to go with the Lunati 60510 cam
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 212/218
Gross Valve Lift (Int/Exh): .531"/.531
What springs, pushrods, should I run with this cam? What other stuff should I upgrade? The engine is out of a 2002 suburban, I did an engine swap on my 70 c-10 swb about 2 years ago and it runs great, but I allways wanted to do a cam and torque converter upgrade. I have the stock rearend it has 3.73 gears. I also want to order a corvette servo. I don't have enough money to upgrade the 4l60e tranny, but so far it has not givin me any problems.
- You may not post replies
- You may not edit your posts
