Well I got bored and did the following...
TB Coolant Bypass
EGR Tube hack down
EGR Restrictor
Removed Plate under open filter
I have no SES lights from the EGR restrictor, I drilled a 3/16" hole. I got some sheet gasket and made my own for it. Need to drive for a while tonight to see any concluisve difference. On the 99-01 trucks (I believe '02+ don't have EGR) the EGR valve is on the passanger side of the motor.
Well I took off that valve. Traced the gasket onto a sheet of paper, the put my paper tracing on a thin piece of aluminum...I used a 24oz MGD can that was readily available.
Basically just sandwich the aluminum part between two new gaskets. I picked up some Mr Gasket Co. shet gasket for ~$7 and made them from my paper template. You COULD buy new gaskets from the local price gouger..er..dealer but I can spend money more efficiently.
The TB is a bit cooler to the touch now...if that makes a diff or not who knows. The 1/4" ID in and out brass fitting was $1.10 at my home away from home...HOME DEPOT. lol
That air box plate...well I did not notice any power differene with it off. I did suck up a TON of bugs so I shook out the filter and put the plate back in. This has been off for a few weeks and decided to post my thoughts on it here. As Hodgee said it is like a "street vacuum"! hahaha.
So far it SEEMS throttle response is better, that's really all. Maybe from idle to 2500rpms. I need to get an unbias opinion on it so I'll get my Pops to drive it and see if he can tell a difference. Ah well, I will get his opinion and toss it up here.
Later all!
