Results 1 to 10 of 73
Thread: New track time... Should it be the time I should expect?
    May 2010
    Oklahoma
    It's a 2001 silverado 5.3, weighs about 4k. It has stock heads with shorty headers and just a gm hot cam, springs, rods and retainers. Built tranny with an edge 3600 stall. 4.11 gears and true trac. Also it has a 100 shot. I am running on the track with 275/45-20 all the way around so I baby it off the line not even stalled up at all. It ran a 12.9 on bottle. Is that where it should be?*Could I cut down the time a bit by putting slicks on or maybe even caltracs? I feel like I should be able to stall up more of the line at the track, even with the 20's. But it just doesn't help. Any help would be great. Thanks
    Sep 2006
    THE 405
    Thats not bad at all. I imagine your 60' is somewhere around 2.1 or so? If you throw some slicks on there the time will drop considerably. I ran 12.86 with a stock converter, 3.73 gears and drag radial on a 75 shot with a 212/218 cam. I see your from Oklahoma. Did you run at Thunder Valley?
    midweststreetcars.com
    May 2010
    Oklahoma
    Yes I did. Do you go up there a lot? Have you ever had a problem with hooking? Or was you always running slicks
    Sep 2006
    THE 405
    I'm there quite a bit. I don't ever have any issues. Thunder Valley is a pretty good track that gets a bad rap from a few haters. We'll there this friday for PSRA. You should come introduce yourself
    May 2010
    Oklahoma
    Is it test and tune? Sorry I'm not sure what PSRA means lol. What do you think my truck would be good to run on slicks?
    Sep 2006
    THE 405
    There are some time only runs but not as many
    PSRA is ProStreet Racing Association. It happens the first friday of every month. Lots of cool, badass cars. Theres an outlaw class that is kind of the main attraction which has some mid 4 second to mid 5 second cars in the 1/8th mile, also a 10.5 class with some really fast cars and then some index racing as well. Like I said, you don't get as many test and tune passes, but its alot of fun.
