Results 1 to 10 of 22
Thread: How To: Paint Your NNBS Tailgate Handle
    Orono, ME
    Cool How To: Paint Your NNBS Tailgate Handle
    Did this as a little project today and figured I'd write a how-to along the way. Enjoy.
    Supplies you'll need:
    -Adhesion Promoter (Helps bond paint to plastic parts) - I used Duplicolor
    -Primer - I used Duplicolor
    -Base Coat - I again used Duplicolor (Olympic White in my case)
    -Clear Coat - Kept with the Duplicolor theme
    -Various sandpapers (80, 120, and 320 grit)
    Tools you'll need:
    -Ratchet/Wrench (13mm)
    -Flathead screwdriver
    Time: 10 mins dis-sassembly, time to sand and paint, 10 mins re-assembly
    Difficulty: Easy
    So, you want to start out by taking out these three screws on the back side of the tailgate...
    Next you'll want to slide your screwdriver in on the top right and left hand sides of the bezel (trim) and pop the clips out... you'll have to apply a decent amount of pressure, so don't be a sally.
    Pictured are the clips that you'll have to pop out...
    Next you need to pull the little bars that unlatch the tailgate off the handle assembly. They are held in by clips and are very easy to pop out and slide out of the way. Pictured below are the clips that hold the bars in place on the handle assembly.
    Once you have the bars off, there is nothing else holding the handle in, you can finagle it out of the hole to be prepped for paint.
    This is what it should look like once you have all the parts out...
    If you need to close/open the tailgate while the assembly is out, just pull on the bars together like pictured below and it'll open...
    Next part is sanding... you'll want to start out with 80 grit and sand until you get most of the texture out of the plastic. Once you finish with 80, move on to the 120 and eventually the 320. After you're done with the 320, there should be no texture left on the plastic and only small/fine scratches.
    This is what it'll look like when you finish sanding...
    Next, if you have a locking tailgate, you'll want to take the tumbler out before you start painting (may want to do this before sanding actually), it is held in by a metal clip and can be easily removed so you don't spray over it...
    Now you can begin to paint... I do it in this sequence:
    2-3 coats of adhesion promoter (5 min between coats)
    3-4 coats of primer (5 min between coats)
    Take a break, get a beer.
    3-4 coats of base coat color (or however much you need to provide adequate coverage) (5 min between coats)
    Take a break, get another beer.
    3-4 coats of clear coat (5 min between coats)
    Let dry for at least a half hour or an hour before trying to put back in truck so you don't mess up your new paint job.
    This is what mine looked like after paint...
    Now for the reassembly... pretty much reverse action.
    Set the tailgate handle assembly inside the hole and put the TOP two screws in finger tight to hold it in place... flip the gate back up and place the bars back in their respective clips, do this by putting the bar in the hole, then moving the clip up and snapping it in place... It'll look like this after you get it all assembled.
    Here's a close-up of how the bars should be oriented...
    Make sure the tailgate works, it should work fine if you got the bars back in right, fairly self explanatory.
    Now you can pop the bezel back on, it just snaps right back in place, be careful and make sure not to scratch your new paint job though. Turn the tailgate back down and put the final screw back in to hold the bezel in place.
    You're done...
    This is what mine looked like afterward :
    Any questions?
    2012 Honda Civic Si - DD
    Feb 2010
    Odessa, texas
    Quote Originally Posted by bartjo06 View Post
    yea i got a question....why did you spray primer over your new paint?
    Orono, ME
    Quote Originally Posted by danger_ranger83 View Post
    Good call edited.
    Quote Originally Posted by Chevy-Art View Post
    It looks factory original. Good job.
    Thanks!
    awesome were did you find that gm duplicolor match.my truck is olmypic white also and i just got my bumpers back from the shop and this could save me some money and downtime if i do it my self.great write up.
    Nothing stock...I either broke it or replaced it before I broke it!!
    Orono, ME
    Quote Originally Posted by 20''strong View Post
    Thanks for the comments! This is the second time I've done something like this, I did a bunch of interior parts on my OBS and they came out just as good, if you take your time, it'll come out awesome IMO. You can get the Duplicolor paint from your local Oreilly's Auto Parts or you can go here http://stores.ebay.com/Spray-Cans-Unlimited
    Dec 2004
    San Antonio, TX Area
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Plainfield, IL
    autozone just started carrying that duplicolor as well
    Houston
    looks good do you plan to do the tailgate cover thingy?
    Orono, ME
    Quote Originally Posted by 408.Luke View Post
    Thanks man, I think I may do the HD cap instead of painting the one that's on there now, haven't really decided yet though.
    Mar 2008
    benbrook tx
    nice write up
    scott
    2008 GMC SLE crewcab factory 20's 5.3 flowmaster CAI
