Results 1 to 10 of 18
Thread: cam suggestions
    New Orleans
    Cool cam suggestions
    idk if these things will totaly contradict eachother but this is want i want
    kinda smooth, not too rough idle
    ok.. with stock verter but best with a 2600-2800
    power past 6k to pull hard up top
    future plans are N/A with a small chance N20 later
    i wanted a tr220 114 but did't want a 3000stall or bigger
    and my mods
    -5.3
    -cai
    -p&p + bypassed tb
    -e-fans
    -Japanese lt's
    -dynomax 3" side exit
    -shift kit + servo
    -trans cooler
    -3.90's w/ trutrac
    -live tune
    07classic
    !MY GARAGE!
    Farmington, MN
    Imo you wouldn't need a 3000 with a tr220
    2000 Sierra rcss, LS6, xr265hr-15, HP Tuner, B&M, traction, cai, 2-4, 3.73 G80, Centerline, Pacesetters w/custom pipes and mufflers
    New Orleans
    What stall would you recommend? I'm not really concerned too much about low end. I just don't want the power band to die early like it does now
    07classic
    !MY GARAGE!
    Augusta, Ks
    2600-2800 would be fine with the tr220....some run it with the stock stall but dont reap all the benefits.
    2004 Buell XB12s
    New Orleans
    i'm probably getting the 220 and a 2800 stall, but don't know which lsa to get. 112 or 114. how much does that 2 degrees change the hp and sound
    07classic
    !MY GARAGE!
    wichita falls, tx
    112lsa will move your powerband up in the rpm range, and will idle rougher, 114 will have the more smooth idle you are looking for and have peak power lower in the rpm range
    Intro Radicalli's
    New Orleans
    yeah i realized that, i want to know how much different ?
    07classic
    !MY GARAGE!
    Quote Originally Posted by banker099 View Post
    112lsa will move your powerband up in the rpm range, . . .
    You have this part backwards. A narrower LSA causes the intake closing to occur sooner, which moves the the powerband down. However, within the powerband, the power will peak a little higher due to the increased overlap caused by the narrower LSA.
    Quote Originally Posted by lukecibilich View Post
    Not enough that you would notice a performance difference. The cam specs are too similar. The slightly higher peak power of the 112 LSA will be offset by the slightly broader power curve of the 114 LSA. The only difference you would notice would be the slightly lopier idle of the 112 LSA.
    New Orleans
    thanks ill just do the 114, should get the stall first or should i do the cam first?
    07classic
    !MY GARAGE!
