Results 1 to 10 of 23
Thread: Torque converter install?
    Well im about to install a verter in my 4l80, my question is am i going to have to remove the hole trans or will i be able to slide it back far enough. Also what am i looking at for work hours, i have all the tools and a car lift.
    Gramercy
    2wd or 4wd?
    id advise you to pull it completely out so you can change the filter an all without worrying if its right or not.
    DISCONNECT the battery
    drop drive shaft
    unbolt the crossmember
    pull the Y-pipe imo
    allow the tranny to drop down
    drop the starter
    pull the 3 bolts for the converter
    pull the clips to the cooler lines or undo the fittings...your choice
    pull out from underneath truck
    pull converter out
    put 1qt in the stall
    install the stall while pushing an turning side to side in short motions you should be able to BARELY fit your finger tips behind the stall an bellhousing
    do everything in reverse
    with air tools an a car lift, tranny jack...4-6hrs depending snags an lunch
    2008 GMC CCSB 6.2/6L80e swap
    Quote Originally Posted by keniff View Post
    I thought the 80e had 6 bolts on the converter?
    Gramercy
    sorry man...your right. 6 from the 80E an 3 from the 60 :/ misread it.
    Thank you very much, yea its a 4x4. And is there any seals i should replace on the trans?
    Dec 2003
    There is a seal on the input shaft they recommend you replace. I have only replaced mine once in about 6 converter swaps.
    2000 RCSB forged ls1, 4l80e, t-76
    10.93@124 1.58 60'
    Well from the looks of it ill be able to slide the cross member across the the torsion bars since i have a lift kit. what you guys think. Ill be back with results next week.
    also i have a slight leak coming from the back of the trans and its slowly dripping all over the transfer case. Im pritty sure there should be a seal back there right?
    Augusta, Ks
    Are you sure its a seal in the trans and not pump rub? Google pump rub and youll see what im talking about.
    2004 Buell XB12s
    Ok that could be a possibility, so what would leak in that case the trans or the transfer case. Because it looks like and smells like trans fluid. Once I drop my tranfer case will i be able to tell if its pump rub?
