Results 1 to 10 of 15
Thread: gear question
    Nov 2009
    Spring, TX
    gear question
    my truck came with 3.23 gears and there an 8.6 now i got 4.10s and someone said the thing the gears attach to(cant remember whats its called right now) will only go up to 3.73s is that true
    Nov 2009
    Appleton,WI
    Yes, you will need a 4 series carrier if the gears are not made to bolt to a 3 series carrier. Find out if they are made that way. The ring gear will be extra thick.
    Nov 2009
    Spring, TX
    Smile
    so if my ring gear is extra thick it will work or will not, and how do i know what extra thick is cause my other gears are still in my truck so i cant compare them
    Nov 2009
    Appleton,WI
    find out the part number
    Augusta, Ks
    I have never heard of anyone having this problem before.
    2004 Buell XB12s
    Nov 2009
    Spring, TX
    Quote Originally Posted by Slow Ride View Post
    which part number, the one for the gears that are already in my truck or the one for the new gears i just got
    Nov 2009
    Appleton,WI
    the new gears
    Quote Originally Posted by michaelweston1@yahoo.com View Post
    No. The ring (annular) gear can be whatever ratio--as long as it is the same as the pinion.
    Nov 2009
    Spring, TX
    Thumbs up
    well i bought a new ring and pinion set along with the master install kit so you think i could put them in for now on the stock carrier untill i save up money for the posi kit
    Yes. All of it will bolt up just fine. You plan on changing the gears yourself or have a shop do it?
