Results 1 to 10 of 21
Thread: 6.0 build and tranny questions
    Oct 2009
    IL
    Ok I'm new here and need a little advice on my project. I have a 6.0L engine that needs a rebuild.(high milage) I'll be removing my 5.3L and replacing it with the 6.0L. I have a set of TSP Stage 2.5 317 heads (thanks Virgil) and will be installing the new FAST™ LSXRT™102mm Intake Manifold with a BBK 90mm T/B. I'm looking to build this engine as a daily driver so reliablity and cost are my prime concern. I was going to go with replacement cast pistons and just a general rebuild on the short block. I'd like some recommendations on a camshaft choice (was thinking about the chevy hot cam) but would like to retain my stock converter for towing. I currently have a 100hp NX kit with all the trimmings, 4/10 gears with auburn diff., shorty headers and KN cold air intake.
    Now the tranny question......I have a 4L60E with the push button towing feature for the tranny. Do all trannies have this feature or do i need to take special care with this type.
    Augusta, Ks
    Ull prolly want to do an 80e swap my friend. That 60e wont last long behind your 6.0
    2004 Buell XB12s
    Oct 2009
    IL
    Yeah Warlock i was going to do that at a later date but after reading a few comments from here i guess it will be sooner than later.
    I have a rcsb so i guess i would need a shorten drive shaft for that swap?
    ff_jeff Guest
    IMO you can keep the stock stall, and weather you have a medium cam or a stocker, you can still tow. If your droppin coin on a fast and heads, might as well have a pro spec you a cam for your needs. I have heard good things about Patrick G. Most people play lawn darts with cam choice.
    Oct 2009
    IL
    Thank's , How would i contact this Patrick G.
    Quote Originally Posted by ososlow1 View Post
    go to ls1tech or performancetrucks.net and search patrick g you'll find him
    or google
    Guerra Motorsports Custom Camshaft Recommendation
    ahh hell here ya go
    Camshaft Help-LS1 Custom Cams-Guerra Motorsports-Patrick G cams
    Simple: 408 on steroids!
    single digits coming soon!
    Oct 2009
    IL
    Damn Skeet thanks!!!!!!!!!
    ...I was going to go with replacement cast pistons and just a general rebuild on the short block...
    Ok, well get the LQ9 pistons then. Trust me. You'll thank me later.
    ...II'd like some recommendations on a camshaft choice (was thinking about the chevy hot cam) but would like to retain my stock converter for towing...
    212/218 .559/.551 116 LSA. The GMPP Hot Cam would not be a wise choice for towing.
    Quote Originally Posted by WARLOCK View Post
    +1.
    ...Most people play lawn darts with cam choice.
    Yeah, if you are an idiot.
    ff_jeff Guest
    +1.
    Then spec him a cam Tyler.
    Awwwww Jeffy...
    I did.
