Results 1 to 10 of 11
Thread: Need to vent!
    Southern WI
    Need to vent!
    So I go get my bottle filled tonight, put ti back in the truck go to leave and it won't start! I listen and no fuel prime, so I don't know what it is with my truck and fuel pumps but it needs to grow up! This is the third time I've had to drop the tank because of the walbro acting up. I keep having problems with the wires connect to it, the gas eats through the shrink-wrap and messes up the connectors. What can I do to stop this? I already have brass terminals on the wires because of the first problem. Then I say screw it and hit the purge button, and it works awesome, but has a leak so I get to fix that too. To top off the night I go over to an ex's house that i recently started talking to again. She tells me that she's afraid of us dating again because her schedule is too busy with school and work, which it is...but really not what I needed to top off the night! Haha just had to get that off my chest, but any advice on the walbro PLEASE GIVE ME!
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Plainfield, IL
    im not 100% familar with the setup..but couldn't you just solder the wires (outside of the tank of course) maybe use some submersible fuel line as the 'heat shrink'...put little clamps or zipties on it.
    Southern WI
    That's the route were going to try now, it's a good pump and isn't making any wierd sounds so I know it's the wiring. All the fuses for everything checked out good and the pump relay clicks when the key is forward like usual...just 0 psi at the rail.
    Mike
    2000 RCSB
    did you atleast get some
    Maui, HI
    Maybe she baited him then gave the ol friend treatment where they talk your ear off thinking you actually give a dang about em. Unless you got to do the banana dance before that happened....
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    Pittsburgh, PA
    do a proper connection instead of halfas5 and there wont be an issue
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    what kind of connectors you using?
    Simple: 408 on steroids!
    single digits coming soon!
    Southern WI
    Quote Originally Posted by skeet View Post
    The brass insulated terminals and then 3 lays of heatshrink over those.
    Mike
    2000 RCSB
    Mike, you don't need to have heat shrink on the wires. You can leave the wires exposed. I would do away with all of the connectors and just solder them.
    Southern WI
    Thanks tyler, I'm going to pull it apart tonight and do that...The wierd part is it sat all night and it started the next morning, ran all day and now it's not running! Haha this is so frustrating, I just want it to run.
    Mike
    2000 RCSB
