Results 1 to 10 of 20
Thread: Nitrous nozzle??
    Feb 2008
    Arizona
    Nitrous nozzle??
    Hey guys, does anyone can help me with this?
    I bought a used nitrous setup from a guy from this forum, it worked great btw.. Well, the thing is, I want to change the amount of nitrous but the guy who installed lost the sheet where it had the numbers to set the amounts..
    My setup is a dual stage, it has 1 Dyno Tune nitrous selenoid, and 1 Sniper nitrous selenoid, same is the fuel; 1 Dyno tune and 1 Sniper.. Do I need to check on each of their websites? Or is it the same? Does it depends on the selenoids brand? Or what does it depends on?? Thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    May I divert your attention to a little writeup Virgil (mean05) did
    http://www.ls1truck.com/forums/power...-jet-list.html
    Feb 2008
    Arizona
    Awesome! Thanks sir! So, that might work for my setup right? Where can I buy the nozzles does anyone know?
    Augusta, Ks
    Nitrous outlet.
    2004 Buell XB12s
    nitrous outlet is the place to go buddy.
    Feb 2008
    Arizona
    Thanks man! I will do my homework trying to get the CORRECT nozzles to set it up to 100hp 1st stage + 100hp 2nd stage.. like yours! Do you remember yours by a chance? I'm about to be done with my standalone system, I just need to figure out how much fuel pressure should I supply the selenoids with.. Any advice??
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by White Devil View Post
    the FP is your choice...i set mine at 58-60psi as you can just use a smaller fuel pill to achieve the correct AFR...say with the Nitrous Outlet nozzle for a 100 shot they will tell you to use a 52n 33f which with the 58psi would put you in the 10.2 AFR range...so to get it in the 11.5-11.8 area you simply go down smaller sizes on the fuel side...so change the 33f to a 31f and see what that does.
    well i can go look during the daylight for ya, i dont remember off hand, idk what my pressure is at id hafta look at my gauge next time, PM virgil he might know my system is his old one.
    Birmingham, AL
    ive seen in a couple places that some people like to run a larger fuel jet and lower pressure to lower the chances of the jet getting clogged, since its a larger hole. is that true?
    01 Silverado
    Feb 2008
    Arizona
    Oh shut.. I need a wideband BAAAD! To be able to do my a/f ratios readings.. Actually, I think I will need it before I hit the 2nd stage button if I dont want to blow anything up.. right?
